engr2GW
Petroleum
- Nov 7, 2010
- 308
1. In ASME B31.3; in chapter VI-Inspection, examination, and testing. It doesn't say anything about inspection as it relates to actual work being done to the new construction, but rather talks about the inpector, but it does talk about NDE under examination including visual, x-ray, magnetic, etc, and also talks about hydrotest and pneumatic tests. Does that mean that the inpectino part of the B31.3 code is just for the description of who's qualified to be an inspector, and what does he/she do in this code OR is the inspector the one that does the examination or just inspects/supervises it.
2. In B31.4; in chapter VI-Inspection and testing. The same thing as above; it just stipulates the qualification of the inspector, but makes detail explaination of the NDE, hydrostatic testing, visual, etc. Does it mean the inspector does the other examination or should be able to supervise it. Or is inspection and examination used interchangeably, is there any post-construction work of quality control done that is called inspection, I see explaination of examination and testing, but not inspection.
3. In B31.8; in chapter IV-Design, Installation, and Testing. here it uses the term "visual inspection"
So;
Is inspection thesame or different from examination.
AND,
Can someone pls let me know if the summary below is a fair partial summary of the three codes
1. B31.3
a. Inspection: qualifying who's to.....???
b. Examination: Non-destructive, e.g. x-ray, visual, magnetic, etc
c. Testing: Hydrostatic and pneumatic, pressure/leak,
2. B31.4
a. Inspection: qualifying who's to....???
b. examination; NDE, e.g. x-ray, visual, etc
c. testing: Hydro, pressure/leak,
3. B31.8
a. Inspection = examination???
b. examination; Non-destructive, e.g. visual, xray, etc... if any??
c. Testing: hydro, pneumatic, pressure/leak,..
Thanks for your help.
So;
AND,
1. B31.3
2. B31.4
3. B31.8
