insert jpeg into drawing
yayaya25
Materials
Jan 3, 2007
36
Does anyone know how to insert a jpeg image into a drawing. I have pictures I want to add into my drawing can you do that?
A very easy way to insert a JPEG is to open the file in MS paint or a similar program. Select the area (or select all) and copy to your clipboard.
Then, in your drawing, simply 'Edit' -> 'Paste' to add it in. You can drag the image or re-size it as you wish.
Thanks,
Lou Monaco
In other words it must be converted to a .BMP (bitmap) file format
Insert\Object\From file - If you get an icon its because the file is not associated to an application that is recognized by Windows... if you don't believe me check the knowledge base... its been a long time issue.
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
Awesome the copy and paste worked out perfect thanks GLED
