Jun 6, 2007 #1 yayaya25 Materials Joined Jan 3, 2007 Messages 36 Location US Does anyone know how to insert a jpeg image into a drawing. I have pictures I want to add into my drawing can you do that?
Jun 6, 2007 #2 MDGroup Mechanical Joined May 22, 2007 Messages 231 Location US A very easy way to insert a JPEG is to open the file in MS paint or a similar program. Select the area (or select all) and copy to your clipboard. Then, in your drawing, simply 'Edit' -> 'Paste' to add it in. You can drag the image or re-size it as you wish. Thanks, Lou Monaco http://www.gledinc.com Upvote 0 Downvote
Jun 6, 2007 #3 tristram Marine/Ocean Joined Dec 10, 2002 Messages 82 Location US In other words it must be converted to a .BMP (bitmap) file format Upvote 0 Downvote
Jun 6, 2007 #4 SBaugh Mechanical Joined Mar 6, 2001 Messages 6,691 Location US Insert\Object\From file - If you get an icon its because the file is not associated to an application that is recognized by Windows... if you don't believe me check the knowledge base... its been a long time issue. Regards, Scott Baugh, CSWP http://www.scottjbaugh.com"If it's not broke, Don't fix it!" faq731-376 Upvote 0 Downvote
Jun 6, 2007 Thread starter #5 yayaya25 Materials Joined Jan 3, 2007 Messages 36 Location US Awesome the copy and paste worked out perfect thanks GLED Upvote 0 Downvote
