Guys,
Let me try to clarify my point with a help of very simple example.
Two components which are designed to mate together:
- solid cylinder with outside diameter [Ø]9.9[±]0.05 (male part);
- cylindrical housing with inner diameter [Ø]10.0[±]0.05 and 0.4mm wall thickness around the slot (female part).
Now, imagine these part made of some kind of rigid material (e.g. aluminum alloy). At a worst-case scenario, due to parts rigidity, it will not be possible to mate them together when the cylinder and the housing both violate their 9.95 envelopes, so designer at the design stage knows the functional limits right away.
Then, think of these parts as of plastic components. A tolerance analysis at the design stage shows nothing different to previous case. But after the items have been manufactured, due to a flexibility of 0.4mm collar, it may occur that the mating is possible even if the envelope of inner diameter is 9.90. Reading your comments to my earlier post, I understand that at this point you will say that if mating was achievable the tolerances were "wrong" (MintJulep) or "too tight" (drawoh). And okay, I understand this. But how can a designer know what is the limit below which the mating of two parts will not be possible? Is it 9.90? 9.80? 9.70? What if the wall thickness was 0.5 and not 0.4? Would the functional limit be 9.92 or 9.94?
And this was/is my point - when dealing with plastic components the answers to those question are not that simple as in case of rigid parts? Designers with 20 years+ of experience will not be able to give you clear answers, trust me. Plus, I am talking here about an extremely simplified case, which is very unlikely to happen in a company designing and producing sophisticated connector systems. So 'the extra table' method is nothing else than an attempt of saying to toolmaker: "You do not have to rework the tool every time. Even though you did not meet the spec, we (design) can live with that because the component still functions." Isn't it opening tolerances up?
And last but not least - I am not saying that this method is the one and only. It has some shortcomings too but I just wanted to reveal one of the possibilities. Nevertheless, I really appreciate your comments.
