Importing STEP files 1
adymech1
57
I tried to import a couple of STEP files into SW2001+ and I get this message:
Can't open the error log file
After this message, SW proceeds to parse and create the model. Finally, I get this message:
"Importing large assembly. Components will be imported and suppressed. Use Unsuppress to show desired parts and sub-assemblies".
I click OK and I don't see anything on the screen. It's a blank assembly. And there is no features/parts in the FeatureManager that I can unsuppress.
What could be going on?
Thanks to all the readers.
Where did your STEP file come from? Did they check the file before giving it to you, to make sure it was a clean file? It is always best to double check your work. It is a habit of mine to check these types of file before sending them out to a customer or supplier.
Also, how did they export the the STEP? AP203 or AP214? You might have them export the model as a AP203 if they used AP214. It seems the industry std for a STEP translator is AP204. I beleive AP214 is mostly used in the automotive industry.
I hope this helps,
Macduff [spin]
Meggitt Airdynamics Inc.
