Import STEP-file
  • Thread starter Thread starter nikko
  • Start date Start date
N
nikko
Guest
I have problems opening a STEP-file. I doesn`t seem to appear in the open directory when i try to open it. If I choose all files, in the open window, it doesn`t show. But if I choose all files in the working directory window the STEP-files are shown.
Nikko,
You must remove any spaces, dots and other illegal characters from the file name.
Rich
Some CAD softwares generate extention .STEP. This is transparent for Pro-E. Change to .stp. This have to work.
Otherwise file me be not compatable by contens or corrupted during translation.
Nikko,
I had the same problem before. This is an easy workaround. All you have to do is rename the file extension. Pro E does not see STEP files so you have to rename it to STP and then try it again.
