I'm trying to import a assembly into teamcenter with tool "Import Assembly Into Teamcenter" in NX.
Everything looks to go alright, but at the end i get the error:
___________________________________________________________________________________________
Unexpected error!
Teamcenter error: The given tag (%1$s) does not exist in the database or is not a persistent object tag.
While importing
"drawing-name"
You should check the state of the output part for problems
This error occurred while
creating Item, Revision and/or Dataset
This error is fatal, and the operation will be abandoned
____________________________________________________________________________________________
Does anybody know what this error means and what i can do to solve this?
Thanks already.
Using NX 8.0 on Windows 7 (64)
Unexpected error!
While importing
"drawing-name"
Thanks already.
