I have a unique situation where I have a 1 story steel framed building with bar joists and metal deck roof. The building is appox. 70'x180'. The problem lies in the fact that the building elevation including the metal deck steps up 2'-0" at 3rd points along the 180' dimension. So that basically means I need a braced or moment frame at those locations. So for lateral resistance to wind loads perp. to the 180' dimension of the building I will need frames at the outer walls and a frame at each of the jogs in the roof diaphragm (total of 4 frames). Do I have any other ways around this? Seems like alot of frames for a building 180' wide. Thanks
