ID SYMBOL-DIVIDED CIRCLE ---- GET INFO FROM PARTS LIST
NXCADUSER
7
I would like show a Divided Circle ID Symbol with the Item Number (on top) and Quantity (on bottom) referencing the information in the Parts List. I am able to create a Circle ID Symbol with the Item Number referencing the info in the Parts List.
Using NX6
What I would do is use "object attributes" for that.
You probably will have to create the oject attributes in you text editor then cut and paste it into your Divided Circle ID Symbol.
It will update with your parts list.
here is a thread to get you started. In the thread the item number is mentioned but you will also see that "qty" is also available as an object attribute.
