I am hitting a road block here and
UtilityLouie
102
I am hitting a road block here and am hoping that this is the correct forum for this question. If anyone thinks there is a better forum for this question, please let me know.
I am having a problem with a vacuum system on the press section of a paper machine. To make sure my piping is not the problem, I have been trying to calculate a pressure drop on my vacuum piping. I have looked at freecalc and efunda. They both have scripts to calculate friction loss of duct, but neither addresses any change in the viscosity of air in the vacuum system.
I would guess that hot (180 degrees) saturated air has a different viscosity than standard air and all calculators use the viscosity of standard air. I think I can make the final calculation myself, but I don't like using numbers that I don't think are correct. Now if the difference in viscosities between saturated hot air and standard air results in less than 5% in the final answer, this should be stated.
I am breaking out the thermo book, fluids book and Crane 410 tonight, but all of the formulas result from there and do not address these concerns.
Am I worrying too much?
Looking for some confidence in the numbers.
I've got an older version (2.1) of the ABZ program (based on Crane 410), and if I punch in atmospheric pressure air (0 PSIG) at 70*F, it says the absolute viscosity is 0.018 centipoise, and the kin vis is 14.953. At 180*F, these change to 0.02 and 20.882 repectively.
Being an older version, it doesn't have any fancy graphics, but I don't care. I LOVE that program. One of the best $150 I ever spent.
Here the output from a simulator that saturates the air. Notice that the air is 53% water at the temperature and pressure (14 psig and 180 F).
K-VALUES: ASOA ENTHALPY: ASOA DENSITY: STD FLOW RATES /HR
VAP VISC: NS81 VAP THC: NS81
TOTAL LIQUID VAPOR TOTAL TOTAL
COMPONENT NAME LBMOL LBMOL LBMOL LB MOL PCT KVALUE
AIR 26.3555 0. 26.3555 763.361 46.120
WATER 30.7898 0. 30.7898 554.689 53.880
TOTAL 57.1453 0. 57.1453 1318.05 100.000
TOTAL LB 1318.05 0. 1318.05
STREAM NUMBER 1
TEMPERATURE DEG F 180.00
PRESSURE PSIA 14.000
ENTHALPY BTU/HR 62859.
VAPOR FRACTION 1.0000
PROPERTIES TOTAL VAPOR
FLOWRATE LBMOL/HR 57.1453 57.1453
MOLECULAR WT. 23.0649 23.0649
ENTHALPY BTU/LBMOLE 1099.9913 1099.9912
ENTROPY BTU/LBMO/R 3.4325 3.4325
CP BTU/LBMOL/R 7.5872
CV BTU/LBMOL/R 5.5764
CP/CV 1.3606
DENSITY LB/FT3 0.047185
Z-FACTOR 0.997059
FLOWRATE FT3/SEC T-P 7.7594
MMSCFD STP 0.520380
VISCOSITY CP 0.012973
TH.COND BTU/FT/HR/F 0.019687
Don't forget that the delta-p should be less than 10% of the absolute pressure or the pipes will choke. Do you have welded or screwed joints? Threads leak (by definition)
