First, thanks for all the replies. And sorry I didn't provide enough detail. I've updated the image to be more representative of the design.
From everything I've seen, if my idea can ever afford injection molding I'll be doing alright. For the foreseeable future, I need to look at alternatives.
>> For instance, that 0.5 mm seems dodgy to manufacture, using machining, for instance, due to low stifness of plastics (especially at a bit higher temps, as during machining).
Yes, I worried about that but those are my design constraints. Is there a stiffer material, like kydex, that retains strength/rigidity when thin?
To machine the part, I would route out the inner cavity from a thicker bar, and then thin it down and shape it from the outside. Does that seem reasonable?
>> Do you mean gouging during machining or during use as a bearing.
I meant that the material needs to be rigid and strong in the final product. The plastic is an encapsulation for some sensitive electronics. It needs to be aesthetically pleasing, and resistant to deformation. Since its thin, it also shouldn't gouge easily.
Hopefully that's enough information? Does anyone see how a vacuum thermoform, or press, or combination of the two might be employed?
Thanks!
