dorodeus78
Computer
Hi!
I need a help, I am a beginner in matlab programming, I a m trying to write a recursive function in matlab with subscripts but I don't how I should represent it, I have just tried to represent it as follow;
Pmbar_nm = a_nm*q*t*Pmbar_n-1,m - b_nm*q^2*Pmbar_n-2,m;
where by I want the nm, n-1,m and n-2,m to be subscripts. As it is when I Run, I'm getting error message that function Pmbar_n is not defined. please tell me what to do!!
The following is the coplete code I have tried to write
function Pmbar_nm = Leg(phi,n_max,t)
%LEG copmutes the normalized associated legendre functions Pnm(t)by recurrence relation
if (nargin == 0)
phi = -6;
lambda = 39;
h = 76;
n_max = 18;
end
if n_max > 180, disp('Upper summation bound too large!'), return, end
GM = 3986004.418e8; % m^3/s^2
a_e = 6378136.46; % m
finv = 298.257223563; % flatenning
% We input geodetic coordinates phi,lambda in degrees
% We have to transform the geodetic coordinates to geocentric coordinates in radians
[X,Y,Z] = frgeod(a_e,finv,phi,lambda,h);
[lambda,phi_geoc,r] = cart2sph(X,Y,Z); % lambda and phi_geoc are now in radians
t = sin(phi_geoc); % phi_geoc is geocentric latitude
%Computing the normalized associated legendre legendre functions along the diagonal
Pbar_nm = zeros(n_max+3,1);
for n = 2:n_max
for m = 0:n
i = 2:m
u = cos (phi_geoc);
Pbar_nm = u^m*sqrt(3)*prod(sqrt((2i+1)/2i));
end
end
% building location array
loc = zeros(n_max+3,1);
for i = 1:n_max+3
loc(i)=i*(i-1)/2+1;
end
% Computing the normalisation coefficients a_nm and b_nm
a_nm = zeros((n_max+3)*(n_max+4)/2,1);
b_nm = a_nm;
for m = 1:n_max+1
for n = m+1:n_max
s = loc(n+1)+m;
a_nm(s) = sqrt(((2*n+1)*(2*n-1))/((n-m)*(n+m)));
b_nm(s) = sqrt(((2*n+1)*(n+m-1)*(n-m-1))/((2*n-3)*(n+m)*(n-m)));
end
end
%Computing the modified associated legendre function
q = a_e/r;
Pmbar_nm= zeros(n_max-4,1);
for m = n_max:-1:2
for n = n_max:-1:m
Pmbar_nm = (Pbar_nm/u^m) *10^(-280);
end
end
disp ('Computed values for the associated legendre function Pmbar_nm'),return, end
Thank you in advance for your consideration!!
if (nargin == 0)
phi = -6;
lambda = 39;
h = 76;
n_max = 18;
end
for n = 2:n_max
for m = 0:n
i = 2:m
u = cos (phi_geoc);
end
end
for i = 1:n_max+3
loc(i)=i*(i-1)/2+1;
end
b_nm = a_nm;
for m = 1:n_max+1
for n = m+1:n_max
s = loc(n+1)+m;
end
end
q = a_e/r;
for m = n_max:-1:2
for n = n_max:-1:m
end
end
