How to retrieve all the body from the parts body collection ?
biw01
Automotive
I am trying to fetch all the bodies from the body collection and then get a face from a particular body inside a part.The way i retrieve the face is by checking its attributes.
My code is as below:
Public Function FnGetFace(ByRef objPart As Part, ByVal faceName As String, ByVal sAttributeType As String) As String
FnGetFace = Nothing
Dim wPart As Part = FnGetNxSession().Parts.Work
For Each body As Body In objPart.Bodies
FnGetNxSession().Parts.SetWork(objPart)
For Each face As Face In body.GetFaces()
'On Error Resume Next
If face.GetAttributeTitlesByType(NXObject.AttributeType.String).Length <> 0 Then
Try
If face.GetStringAttribute(sAttributeType) = faceName Then
'If face.Name = faceName Then
Dim sJournalIdName As String
sJournalIdName = body.JournalIdentifier + "|" + face.JournalIdentifier
FnGetFace = sJournalIdName
SSetWorkPart(wPart)
Exit Function
'End If
End If
Catch ex As Exception
End Try
End If
Next
Next
SSetWorkPart(wPart)
Err.Clear()
End Function
Can someone please point out what i have missed in the code as i am not able to retrieve all the bodies from the part ?
Below is an admittedly rough journal that will search through an assembly for a face that has an attribute with a given title. Hopefully, you can adapt it for your needs or at least borrow from the strategy it uses.
Code:
' This assumes that the work part is the top-level assembly part.
' journal walks the assembly structure searching for a face with the given attribute title
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module NXJournal
	Public s As Session = Session.GetSession()
	Public ufs As UFSession = UFSession.GetUFSession()
	Public lw As ListingWindow = s.ListingWindow
	Sub Main()
	Dim dispPart As Part = s.Parts.Display
	'change the following to the title of the attribute you want to search for
	Dim faceAttribute as String = "MYFACENAME"
	lw.Open
	Try
		Dim part1 As Part
		part1 = s.Parts.Work
		lw.WriteLine("Top: " & part1.Name)
		Dim c As ComponentAssembly = part1.ComponentAssembly
		Walk(c.RootComponent, 0, faceAttribute)
	Catch e As Exception
		s.ListingWindow.WriteLine("Failed: " & e.ToString)
	Finally
		Dim nullAssemblies_Component As Assemblies.Component = Nothing
		Dim partLoadStatus2 As PartLoadStatus
		s.Parts.SetWorkComponent(nullAssemblies_Component, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus2)
		Dim workPart As Part = s.Parts.Work
		partLoadStatus2.Dispose()
	End Try
	lw.Close
	End Sub
	Sub Walk(c As Component, level As Integer, myFaceAttribute as String)
		Dim children As Component() = c.GetChildren()
		Dim child As Component
		Dim prototype As Part
		If TypeOf c.Prototype Is Part Then
			prototype = CType(c.Prototype, Part)
			For Each child In children
				lw.WriteLine("")
				lw.WriteLine("child: " & child.Name)
				'lw.WriteLine("path: " & child.Prototype.OwningPart.FullPath)
				FindFace(child, myFaceAttribute)
				Walk(child, level + 1, myFaceAttribute)
			Next
		End If
	End Sub
	Public Function GetUnloadOption(ByVal dummy As String) As Integer
		Return Session.LibraryUnloadOption.Immediately
	End Function
Sub FindFace(myComp as Component, myFaceAttribute as String)
	Dim partLoadStatus1 As PartLoadStatus
	s.Parts.SetWorkComponent(myComp, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus1)
	partLoadStatus1.Dispose()
	Dim myFaceName as String
	Dim found as Boolean
	lw.Open
	For Each myBody as Body in workPart.Bodies
		'lw.WriteLine("Found a body: " & myBody.Tag.ToString)
		For Each myFace as Face in myBody.GetFaces
			Try
				myFaceName = myFace.GetStringAttribute(myFaceAttribute)
				lw.WriteLine("Face found, name: " & myFaceName)
				'if myFaceName = "value of attribute you are searching for" then...
				myFace.Highlight
				exit sub
			Catch ex as Exception
			End Try
		Next
	Next
	if Not found then
		lw.WriteLine("Face not found")
	end if
End Sub
End Module
Thanks for the code . i will deeply examine the code and get back to you if i need more help.
what does this piece of code do ?
I also see an option of EntirePart in the RefsetOption.
Which one to chose ?
