How to model this part? 3
Bailar
Computer
I need to model this part :
I'm trying to use Revolve and and Extrude :
The question is How to trim unnecessary pieces? or maybe I should use another methods to model this part?
Something like this?
it's an NX5 part. Hope you can open it.
I revolved the bottom half with "stock" on top...
I chopped the swoop with an extrude(thats what the stock is for)...
finally, I revolved the top taper and united it.
Thats my guess!
JAY
 http://files.engineering.com/getfile.aspx?folder=70099716-37a3-4fd6-a5c4-bc0419ba4ad5&file=challenge.prt
Based on the appearance of the image the sides appear to flatten out so just roughly using Jay's geometry I have added in a few steps to arrive at the following result. You might take the time to model something more carefully. I really just intended to illustrate the use of face blends in this instance.
I think Jay's solution to boolean three elements is otherwise the correct approach. It also appears from the image that the two tapered ends may in fact not be co-axial (slightly off centre). It wouldn't change the construction.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
 http://files.engineering.com/getfile.aspx?folder=af3b425a-5662-438f-83ac-3d64c6c0e9ce&file=challenge.prt
Thank you guys. That's exactly what I need.
hello any one give me one or 2 examples of ug nx5 4th (a) axis maching pragram..
