Turns out he meant the elbow was bent through 105 degrees so the internal angle is 75 degrees. There is a setting in maximum allowable bend angle in the configuration that can be adjusted higher. Also, as LittleInch mentioned you can put two bends end to end. I did two at 52.5 degrees and it worked.
