This used to work prior to NX9... Now we have NX9 and... Picture this...
I draw a solid model of a cylinder. Pretend that's the bolt. Then I draw another cylinder. Pretend that's the nut. Then I draw a centerline between the two, kinda like what you might see on an exploded drawing. Your model ends up looking like this... see picture.
Now I want to create the drawing, and I want the centerline to show up on the drawing. But it doesn't... the centerline is not view dependent. It's a model line. Everything is on layer 1 to eliminate confusion.
How do I make that line show up on the drawing?
UGGuy!
UGGuy!
