how to make a rack + pinion move(motion)
  • Thread starter Thread starter jbelle7435
  • Start date Start date
J
jbelle7435
Guest
I am having trouble having my rack and pinion move along each other. IF anyone has ever did that before using pro-mechianca motion that would be great to help me.....
I want my rack to move up and down when the bar is pulled which is attached to the pinion shaft in this picutre below...
Edited by: jbelle7435
Try to use cam connections - each rack tooth with the corresponding gear tooth. It should work.
I did use cam connect. Did not work. I need a tutorial to figure it out in this case?
did u allow lift off? on the cam connection?
send me the rack and pion part of ur design and i will have a play with it
also tell me the relative hights of where they are suposed to be :)
Hi jbelle7435. First of all I like your name...<B style="mso-bidi-font-weight: normal"><?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />[/B]
For rack and pinion you don
