How to get the unused expressions?
anthonyo
4
Hi
I want to get the unused expressions in the part by open api, but has no found the function, who can help me?
thanks
All you have to do is go to tool==>expression=> and under listed expressions change it to unused expressions.. This will show you all unused expressions.
Hope thats what you wanted to know!
To check in a display part the following code would help.But need to add few more checks for identifying interpart exps, geometric exps ....
Try executing this as a journal
Imports System
Imports System.Windows.Forms
Imports System.Collections
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpenUI
Imports NXOpen.Utilities
Imports NXOpen.UF
Public Module query
Public UFS As UFSession = UFS.getufsession
Public NTS As Session = NTS.getsession
Sub Main()
Try
' / Get the displayed part /
Dim dispPart As Part = NTS.Parts.Display
' / Retrieve part expressions /
Dim partExps As ExpressionCollection = dispPart.Expressions
Dim unusedExps As New ArrayList
Dim t_expn As Expression
' / Iterate through the expressions in the part /
For Each t_expn In partExps
If (t_expn.GetOwningFeature Is Nothing) Then
' / Add the unused expression into arraylist /
unusedExps.Add(t_expn)
' / Direct the information to window /
writeToWindow(t_expn.Name + " : " + t_expn.Value.ToString)
End If
Next
Catch ex As Exception
MessageBox.Show("Retrieving expression not sucessful", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
End Sub
Sub writeToWindow(ByVal strContent As String)
Try
' / Check for the status of the listing window /
If Not (NTS.ListingWindow.IsOpen) Then
NTS.ListingWindow.Open()
End If
NTS.ListingWindow.WriteLine(strContent)
MessageBox.Show("Unable to write to listing output device", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
End Sub
I get two compile errors when cutting/pasting that code
Line 11: 'Module' statement must end with a matching 'End Module'
Line 33: 'GetOwningFeature' is not a member of 'NXOpen.Expression'
Justin Ackley
Designer
I has found that some expressions link with sketch and drawings,not only features. how to retrieves these expressions?
Hi anthonyo : Kindly change the "t_expn.GetOwningFeature" to "t_expn.GetUsingFeatures", this would even include sketch and all registered features
Hi Jackley : I am guessing that you are using NX4.0.0, if you can try my code with NX4.0.3.3. the compilation and non-reference errors may dissolve.
Hi HariharanB: I use the UF_MODL_ask_features_of_exp() to retrieves the unused exps and the UF_SKET_ask_exps_of_sketch() to retrieve the used exps in display part, also need to identifying some other exps.
