hi MintJulep
I realise that the roof as to cope with the full temperature swing from summer to winter which may well be +100 deg C to -10 deg C however if we make a steel frame in a factory at 15 deg C then the temperature range or ranges would be (100-15) summer and (15-(-15)) winter so in the summer months to work out expansion of the frame it would be based 85 deg C range and in the winter the contraction would be based on a 30 deg range.
I suppose if you assumed 115 deg C range for both expansion and contraction it would be very conservative but I was never taught to do it that way.
Well I assume the OP as got the information he requires now at least.
regards
desertfox
