How to do modal analysis with damping of material?
enjoywithme
I want to obtain the modal damping with material damping input....looking forward help....
Hello!
You could use as method for extraction
DAMPED or QR DAMPED
Best wishes,
Juzz
Justin Onisoru
Researcher
Romanian Academy
Institute of Solid Mechanics
Thanks the answer from Justin Onisoru.
I have tried the DAMPED and QR DAMPED method. But the result is so strange, I got no any complex frequency.
I paste the operations here...
/PREP7
ET,1,SHELL63
R,1,4e-3,4e-3,4e-3,4e-3, , ,
RMORE, , , ,
RMORE
RMORE, ,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,1e9
MPDATA,PRXY,1,,0.3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,1.5e3
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DAMP,1,,0.009
RECTNG,0,0.5,0,0.5,
LESIZE,ALL, , ,20, ,1, , ,1,
amesh,all
FINISH
/SOLU
ANTYPE,2
MODOPT,DAMP,30
EQSLV,FRONT
MXPAND,30, , ,0
LUMPM,0
PSTRES,0
MODOPT,DAMP,30,5,5000, ,OFF
/STATUS,SOLU
SOLVE
Hello, enjoywithme!
I run your input and it seems to work pretty well.
I obtain 30 frequencies (not all are complex) but it's ok.
So, this is my advice:
1) At the beginning of your input add a command that redirect your output to a file:
/output,file_name,extension,path (default to current directory),mode_of_writting (overwriting or append)
but /output,output,out will be enough
List this file and you will see the frequencies (preceding participation factors calculus)
2) Ifyou don't want to write the output in a file when you open "Results summary..." under /post1 you will see that every substep appears twice. First is the real part, second is the imaginary part.
Best wishes,
Juzz
Justin Onisoru
Researcher
Romanian Academy
