I ran into an interesting scenario that I wasn't sure of the best way to handle. I'd like to define a feature that exists at MMC, but doesn't exist in the nominal profile of the part.
The particular geometry that I'm looking at is a machined radius that breaks out of a cast surface. I'd like the surface to continue on at an angled taper when the casting is at MMC, rather than for the radius to continue to turn outward. Trouble is, I'm not sure how to define the taper, since it doesn't exist at nominal tolerance.
I suppose that I could model the casting at MMC with a unidirectional profile, but I can see that causing all sorts of trouble with the casting vendor. Is it legal to define the remainder of the profile with phantom lines? Thoughts?
Thanks for the help.
//signed//
Christopher K. Hubley
Mechanical Engineer
Sunpower Incorporated
Athens, Ohio
//signed//
Mechanical Engineer
Athens, Ohio
