How to create 3D helix curve
  • Thread starter Thread starter pops
  • Start date Start date
P
pops
Guest
Hello everybody,
Please tell me how to create a 3D helix on a shaft. i need to cut a helix profile on a hallow shaft.
thank you
Girijesh
wrap a straight line around the shaft.
then use sweep cut using this curve.
Israr
Hi guy!
Tell the version of ProE you are using.So that I may explain it clearly.
Khurshid
use relation the angle dimension like that sd#=trajpar*360*10, 10 is loop numbers.
first ,sketchor extract two curves then use the variable section sweep.
second, use the variable section sweep pick cuves to sweep,that in sketch make a construct circle and a line,
dimension angle to the line use relation like sd#=trajpar*360*10, so you create a
helix sweep surface .
third, extrat helix curve from the helix sweep surface!!!!!!!
lee from China PRC
Edited by: yeehlee
