Good day all
I have run 2 models; the first plate with hole, the second is the same plate geometry but attached on one surface side to 2 other solid plates so the stiffness at the second higher than the first.
we need to compare the stresses at the hole for the 2 models. we use displacement control
both models loaded with the same displacement at one end (ramp load at 10 seconds, in standard Abaqus)
We got the reaction force at both models over the displacement load (Reaction force vs the displacement (at the loaded edge))
How to pick the accurate point for comparison the hole stress at the two model for the same load. at the same displacement or at the reaction force.
Attached the reaction force vs the displacement load increase for both. for a fair comparison of stresses is at the same displacement loaded both or at the same reaction force of both
Comparing at the same displacement I got plastic-strain higher at the stiffer model which it should not.
in the same reaction force (results from displacement at a different stage in both models) I got a logical result, less deformation at the stiffer model. But how to explain that, I mean why the comparison at the same reaction, not the displacement
see the attach, please
your comment, please
