OGMetEngr, I have not defined "average yield strength" as I have been searching for a long time for a definition and have not been able to find one. I'm assumming that "average" would be in the context of the mean yield lying between the low and high points of the yield curve. But since I'm not a metallurgist, nor possess any background in metallurgy, I understand that I risk sounding like a fool by that assumption. I would love to stand corrected.
As to the material I'm working with, well, that varies. I'll try to be brief in a fuller explaination of what I'm after and why.
My profession is that of a tooling designer. I take a metal product, be it for automotive, telcom, computing, appliance, or any other industry, and design a stamping tool (die) by which the product is mass produced. That tool is then placed in a stamping press; be it mechanical or hydraulic. A flat sheet of steel is fed into the tool as a blank or from a coil on a reel. In the case of a progressive die (a die with multiple stations for cutting and forming) the steel sheet is fed incrementally with each press stroke, each station performing either a cutting or forming operation, until the part is complete per the customer's part specifications.
Since I design for multiple industries with a wide range of applications the material varies; almost all CRS grades, various grades of high strength low alloy, stainless grades at various tempers, aluminum, copper, brass . . . etc.
One aspect of tool design is the need to calculate forces for cutting and forming. As an example, to bend a given material with a given thickness at a given angle I have to determine 1) the bending force and 2) the clamping force required so that the material does not pull while being forming. Calculations are made using industry standard formulae that take into account all of the particular variables.
One other calculation I need to make is "bottoming" force. Generally, all forming operations need to "bottom." In other words, at the bottom of the press stroke the stack-up of all plates top to bottom, including material, is solid. Bottoming produces added force and it is calculated using the following formulae:
Minimum bottoming force = Minimum yield strength x material thickness x length of bend / 2000
Average bottoming force = Average yield strength x material thickness x length of bend / 2000
Now, the stamper for whom I design the tool needs to know how much tonnage my design will produce (adding up all cutting, forming & bottoming pressures along with nitrogen cylinder/spring pressures used for clamping and stripping) in order for him to designate what size (tonnage) press to run the tool in.
I must make mention that the total force generated by any given tooling design need not be calculated to a degree of accuracy requiring one or more decimal places. The force value should be fairly accurate give or take a few tons. Press sizes range in tonnage. A 300 ton press, for instance, can run any tool that generates less than 300 tons. So often times a tooling design is well within the press tonnage capacity and the precise tonnage of the tool need not be calculated very accurately. On the other hand, if a stamper has an option of running a tool in a 150 ton press or a 200 ton press then the tonnage calculations I make need to be more accurate.
Hopefully, this explanation helps.
If calculating "minimum" or "average" yield strength is something that can fairly easily be done given general material specs supplied by a steel vendor then I would be happy. If it cannot be done from a spec sheet but only through analysis then I'm out of luck. I would then at best hope for a formula that approximates and which is not hugely off.
I appreciate the comments thus far and thankful for the education all of you are providing me.
Western Design Services Co. Ltd.
Bangkok, Thailand
Chicago, Illinois USA
