B
bhayden
Guest
I understand that dimensions displayed in Magenta are because they cannot be regenerated. For example, the feature they reference has been deleted. What about a feature itself? I removed a hole that was created using two features, a section cut and a chamfer in 2000i2, and replaced it by inserting a standard hole in 2001. I cleaned up all the dimensions but there is still a hole showing up in all views of the drawing. The original hole was dimensioned in a section view. I left the plane defining the section and it makes no reference to the original feature. there is also a very similar mating part which I made the same changes to and although the dimensions were highlighted it doesn't have the phantom feature.
Bernie Hayden
XKL LLC
Bernie Hayden
XKL LLC
