How do you do Fractional Dimensions?
  • Thread starter Thread starter Quantum_Pr
  • Start date Start date
Q
Quantum_Pr
Guest
I want to display dimensions as fractions instead of decimals, how to I change this?
Goto Modify > Dimension, select dimension.
In dialog box, select 'Fraction'.
That doesn't work in the drawing mode, does it? I can go into the part mode and select modify>dimension and select the dimension and change it to fractional, but this does not make it show up as fractional in the drawing mode. How do I make it show up as fractions in my drawings?
If your dimensions on the drawing are Shown or driven, this should make it appear as a fraction in the drawing. Click View > Update > All Sheets (in Pro/E 2001) to manually update the drawing.
I figured it out. When you are drafting in the drawing mode, and you want to change from decimal form to fractional form, you first need to select the desired dimension. After the dimension is highlighted, select Edit > Properties then select the Fractional option within the Format box on the Properties page in the popup window. Finally select OK.
