I figured it out. When you are drafting in the drawing mode, and you want to change from decimal form to fractional form, you first need to select the desired dimension. After the dimension is highlighted, select Edit > Properties then select the Fractional option within the Format box on the Properties page in the popup window. Finally select OK.
