This is probably an easy question, & I'm not happy that I can't figure it out myself, but I'm trying to experiment with magnesium as a sacrificial electrode as a means of preventing rust formation on my car. I live in the Chicago area so there is plenty of salt and damp weather in the winter.
I'm using conductive glue because another thing I experimented with has a conductive rubber positive electrode glued to the chassis with conductive glue.
I've attached the Mg slugs to the underside of the car in several locations where they would get wet, but most do not seem to be reacting. Only 1 corroded a lot during 1 winter season. Should I use non-conductive glue? Other sacrificial anode circuits I've seen all show the anode connected to the metal to be protected (i.e. the circuit does not need to be completed by the surrounding salt solution.
Ideally, I'd like to extend the conductive rubber electrodes to several areas on the body of the car but I'd like to be sure I attached them properly.
BTW, the electric gizmo supplies a vew volts (+) and a limited current to the conductive rubber so that the oxidation half of the reaction occures on the rubber instead of on the chassis of the car. It's been in use for 13 years and I've had little body rust. However, the chassis underneath is as rusted as any other car. I can't completely explain this. Maybe it's not working at all. It sounded like a valid method when I bought it.
