How can I measure the lenght of a spline?
Matrix
15
Hi all,
Can I measure the lenght of a spline or a pline?
Thanks in advance
Matrix
1. Use the command 'list', it will give you length along with coordinates of vertces, etc.
2. Use 'area', it gives you length as well as area.
3. Use 'lengthen', it gives you cuttent length, then 'esc' to cancel.
If programming, use 'area', then the length is stored in the System Variable 'perimeter'.
Carl
