How can I do this?
JTDillard
8
I have this drawing of a part I need to make a model of. I have the revolved part completed which is the bore and OD taper. I am not sure how to make the swept features on the outside that follow the tapered at a helix and taper down as they go around. I someone could please help I would really appreciate it.
Thank you,
JT
I'd do the cylinder first...
Then put a draft on it...
Then put the helix on...
Then put the rounds on.
It seems quite straight forward.
It's not really straight forward, as the helix must follow the taper properly. I second Fawkes. You need to create the mathematical equation for the tapered helix. Once that's done, you should be able to sweep a section along the curve.
V
If the helical feature is tapered a Helical Sweep feature should fill the bill (see Help for a tapered example), but it looks to me like the helical feature in the drawing is constant diameter.
(If a "true" representation is required there are other nuances that should be considered. Similar to cutting a helical groove, simply sweeping a planar section probably won't bring home the trophy.)
If the helix is straight or tapered it make no difference.
Making it tapered can be as easy as adding a revolved cut at the end.
