unxgtrwd
Computer
- Mar 27, 2009
- 3
Hello people. I have a 30cc OHV engine from a Stihl FS65-4 strimmer. On the inside of the plastic casing it says Honda G30, so I guess this is the model of Honda engine.
I have taken it apart for a learning experience. Everything seems in good order, so it is just a case of putting it back together... However, I have not been able to find any technical details for this engine, and am not sure how to set the valve timing correctly.
On the nylon cam gear, there are some marks, two of which look to be marker pen - I guess these marks corraspond to the position of the cam lobe at TDC?
How do I set the timing on this? And does anyone know for sure which model of engine this is/have a service manual for it? Also, what is the mechanism on the back of the cam lobe for?
If any more pictures are required, no problem.
