I have journal for create thread with holePackageBuilder (record by NX and edited by me).
I would like add attribute for created thread as body (when BooleanOperation.Type = None) or feature (when BooleanOperation.Type = Substract).
It is possible get body or feature from holePackageBuilder for use in next operation?
Best regards
MANok
NX2207
Tc14
Code:
Sub Create_thread(myPointTag As Tag, startPointTag As Tag, ThreadDepth As String, ThreadSize As String, TapDrillDiameter As String, ThreadedHoleDepth As String, thread_type As String, substractType As Boolean, direct As Boolean)
Dim nullNXOpen_Features_HolePackage As NXOpen.Features.HolePackage = Nothing
Dim holePackageBuilder1 As NXOpen.Features.HolePackageBuilder = Nothing
holePackageBuilder1 = workPart.Features.CreateHolePackageBuilder(nullNXOpen_Features_HolePackage)
Dim n_parents As Integer
Dim parentTags As Tag()
Dim line1 As NXOpen.Line
theUfSession.So.AskParents(myPointTag, UFConstants.UF_SO_ASK_ALL_PARENTS, n_parents, parentTags)
For Each parentTag As Tag In parentTags
Dim parent_object As TaggedObject = Utilities.NXObjectManager.Get(parentTag)
If parent_object.ToString.ToLower.Contains("line") Then
line1 = parent_object
End If
Next
Dim point1 As NXOpen.Point = Utilities.NXObjectManager.Get(myPointTag)
Dim startpoint As NXOpen.Point = Utilities.NXObjectManager.Get(startPointTag)
Dim nXObject1 As NXOpen.NXObject = Nothing
Dim xform1 As NXOpen.Xform = Nothing
xform1 = workPart.Xforms.CreateExtractXform(line1, NXOpen.SmartObject.UpdateOption.WithinModeling, False, nXObject1)
Dim line2 As NXOpen.Line = CType(nXObject1, NXOpen.Line)
Dim direction2 As NXOpen.Direction = Nothing
If Not (Math.Abs(line2.StartPoint.X - point1.Coordinates.X) < 0.000001 And Math.Abs(line2.StartPoint.Y - point1.Coordinates.Y) < 0.000001 And Math.Abs(line2.StartPoint.Z - point1.Coordinates.Z) < 0.000001) Then
direction2 = workPart.Directions.CreateDirection(line2, NXOpen.Sense.Reverse, NXOpen.SmartObject.UpdateOption.WithinModeling)
Else
direction2 = workPart.Directions.CreateDirection(line2, NXOpen.Sense.Forward, NXOpen.SmartObject.UpdateOption.WithinModeling)
End If
If direct = False Then
Dim success1 As Boolean = Nothing
success1 = direction2.ReverseDirection()
End If
holePackageBuilder1.ProjectionDirection.ProjectVector = direction2
holePackageBuilder1.Tolerance = 0.00001
holePackageBuilder1.ScrewStandard = "ISO"
holePackageBuilder1.ThreadStandard = thread_type
holePackageBuilder1.StartExtensionEnabled = False
holePackageBuilder1.HolePosition.DistanceTolerance = 0.00001
holePackageBuilder1.HolePosition.ChainingTolerance = 0.0000095
holePackageBuilder1.ThreadedReliefDepth.RightHandSide = "0.5"
holePackageBuilder1.ThreadedReliefDiameter.RightHandSide = "1"
holePackageBuilder1.ThreadedReliefChamferOffset.RightHandSide = "0.08"
holePackageBuilder1.ThreadedStartChamferDiameter.RightHandSide = "1"
holePackageBuilder1.ThreadedEndChamferDiameter.RightHandSide = "1"
holePackageBuilder1.EndHoleData.TapDrillDiameter.RightHandSide = "0.75"
holePackageBuilder1.EndHoleData.ThreadedStartChamferDiameter.RightHandSide = "1"
holePackageBuilder1.EndHoleData.ThreadedEndChamferDiameter.RightHandSide = "1"
holePackageBuilder1.EndHoleData.ThreadedReliefDepth.RightHandSide = "0.5"
holePackageBuilder1.EndHoleData.ThreadedReliefDiameter.RightHandSide = "1"
holePackageBuilder1.EndHoleData.ThreadedReliefChamferOffset.RightHandSide = "0.08"
holePackageBuilder1.RadialEngageOption = "Custom"
holePackageBuilder1.Type = NXOpen.Features.HolePackageBuilder.Types.ThreadedHole
holePackageBuilder1.ProjectionDirection.ProjectDirectionMethod = NXOpen.GeometricUtilities.ProjectionOptions.DirectionType.Vector
holePackageBuilder1.ThreadLengthOption = NXOpen.Features.HolePackageBuilder.ThreadLengthOptions.Custom
holePackageBuilder1.HolePosition.SetAllowedEntityTypes(NXOpen.Section.AllowTypes.OnlyPoints)
holePackageBuilder1.HolePosition.AllowSelfIntersection(True)
Dim targetBodies1(0) As NXOpen.Body
If IsSubstract = False Then
holePackageBuilder1.BooleanOperation.Type = NXOpen.GeometricUtilities.BooleanOperation.BooleanType.Create
Dim nullNXOpen_Body As NXOpen.Body = Nothing
targetBodies1(0) = nullNXOpen_Body
Else
holePackageBuilder1.BooleanOperation.Type = NXOpen.GeometricUtilities.BooleanOperation.BooleanType.Subtract
targetBodies1(0) = Body1
End If
'targetBodies1(0).SetUserAttribute("EndsType", -1, "9ENM10x60", Update.Option.Now)
holePackageBuilder1.BooleanOperation.SetTargetBodies(targetBodies1)
holePackageBuilder1.ThreadDepth.RightHandSide = ThreadDepth '"10"
holePackageBuilder1.ThreadSize = ThreadSize ' "M10 x 1"
holePackageBuilder1.TapDrillDiameter.RightHandSide = TapDrillDiameter '"9"
holePackageBuilder1.ThreadedHoleDepth.RightHandSide = ThreadedHoleDepth '"12"
Dim points1(0) As NXOpen.Point
points1(0) = startpoint
Dim curveDumbRule1 As NXOpen.CurveDumbRule = Nothing
curveDumbRule1 = workPart.ScRuleFactory.CreateRuleCurveDumbFromPoints(points1)
Dim rules1(0) As SelectionIntentRule
rules1(0) = curveDumbRule1
Dim nullNXOpen_NXObject As NXOpen.NXObject = Nothing
Dim helpPoint1 As NXOpen.Point3d = New NXOpen.Point3d(0.0, 0.0, 0.0)
holePackageBuilder1.HolePosition.AddToSection(rules1, nullNXOpen_NXObject, nullNXOpen_NXObject, nullNXOpen_NXObject, helpPoint1, NXOpen.Section.Mode.Create, False)
Dim nXObject3 As NXOpen.NXObject = Nothing
nXObject3 = holePackageBuilder1.Commit()
holePackageBuilder1.Destroy()
End Sub
Best regards
MANok
NX2207
Tc14
