maximalover
- Apr 22, 2005
- 5
We are currently running SWx 2005 SP2. I have run into instances where an individual has changed the name of a hole wizard feature (adding "_8X" or something similar) in a part to clarify a set of holes. If the feature changes to a drilled hole instead of the original tapped hole, the description in the feature manager does not update/change to the new type/size of hole.
Is this something that is a bug in 2005, or is this just the way the software is regardless of the revision?
