lonsgsp
- May 31, 2005
- 37
I have a simple plate with a fair number of threaded holes. Also on this plate there is text that will be impression stamped onto the part. I have used the cut-extrude feature to show this on the part.
I am using the hole table function to locate the holes. Problem is the hole table is locating each character of text as well as the location of each hole.
I poked around and cannot find a way to have the hole table ignore the cut-extruded text. Is there a way around this?
Thanks,
Lon
Thanks,
Lon
