somervil09
- Sep 24, 2018
- 5
Hello All,
This may be a simple question, but I haven't seen a clear illustration that directly addresses my situation. I need to establish a secondary datum using a pair of holes, the datum being the midpoint between the two centers (point P). See the attached sketch for illustration. The rotation of the part should be defined by the dia.12 hole at the center of the part. Essentially I want to define point P as the X,Y origin and fix rotation using the third hole. Calling out the 2-hole pattern as datum B would fully constrain the part without regard to the third hole (correct??), so what would be the best way to establish the DRF as I would like it to be?
