We had to design some dunnage steel that is supported on posts that sit on existing columns on the roof of a building. We did some props in order to locate the columns and realized that the slab construction is made with cinder concrete. There are steel beams from column to column 16" deep however the slab is just gravel-like. we were able to put a rod through 5'-0 down all the way to the ceiling. At The contractor was able to pull out a steel rod 8'-0 long that had rusted.
I suspect that the rod is sort of a tension reinforcement. if there are more rods and they are rusted then will we have a collapse? Maybe. So how do i start investigating this case? I was just hired to do the dunnage. How is the new investigation introduced? I simply do not know if there is a real problem. Any ideas will be highly appreciated.
