TehMightyEngineer
- Aug 1, 2009
- 3,073
I have a large slab design that requires a high point load in random locations. Basically 10,000 psi on a 9" circle or less. A possible solution is just a movable baseplate that the client has to locate under the load each time; however the client was rightly concerned that this may not happen all the time due to laziness of the operator and/or the plate gets damaged or misplaced.
I'm only at the conceptual stage so this is the perfect time to propose ideas for a system. My thought was a high strength concrete mix with poly macro fibers and a surface hardener. Seems like this should get the compressive strength of the surface up to the 10,000 psi require and then I can just reinforce the slab to keep it from coming apart from the internal compressive stresses. However, I'm not sure if this is feasible for the pressures we're talking about.
Anyone have any other proposed systems we might look at?
Ian Riley, PE, SE
Professional Engineer (ME, NH, VT, CT, MA, FL) Structural Engineer (IL, HI)
Ian Riley, PE, SE
