Sparky4598
- May 4, 2024
- 22
Trying to diagnose some vibration issues here in a large 8,600hp VFD driven electric motor. Bearings are pressurized oil journal bearings. Directly coupled to another motor to apply a load, so no gear mesh frequencies or blade pass frequencies possible here. Frame is rigidly bolted to a stong floor and properly shimed. Rotating frequency is 500rpm.
The frequency analysis shows something i have never seen before. The acceleration components for 1x-~15x are very low, but there are multiple large spikes around 500Hz and 1kHz. I believe the carrier frequency for the VFD is 500Hz.
Does anyone have any insight here as to what could be causing this? Or any suggestions of things to check? The controller is shutting down the system because of the large vibrations in the higher frequencies.
Thanks in advance for any suggestions!
