I am attempting to calculate the NPSHA for a centrifugal pump in a system I am designing. I have checked over my calculations and come up with a number that looks to be technically correct but does not seem intuitively correct. I want to get a second opinion to see if I did something wrong.
Inputs:
Liquid is water at 80F and sea level
Flow is 4.2 l/min
Pump inlet is 1” ID
Tank level height above the pump inlet varies from 3 ½ feet to ½ foot
The run from the tank to the pump is in 2 sections:
First section is 15 feet of 1” ID Buna hose
Second section is 2 feet of 1” 316 SS pipe with (1) 90 degree elbow and (1) ball valve which is fully open when the system is running
The numbers I came up with are Average Re = 4100 and NPSHA = 36 feet.
The one area I am unsure of is the supply tank. The tank is a 30 gallon cylinder lying on its side. It is filled through an opening at the top which is closed with a screw-on lid. The lid is not airtight so I included atmospheric pressure in the above calculation. If I use 0 feet for atmospheric head then the NPSHA comes out 2.29 feet. So a more intuitive answer would be something less than 34 feet of atmospheric head (34 feet atmospheric = 36 feet NPSHA).
Inputs:
Flow is 4.2 l/min
Pump inlet is 1” ID
