sheevaraam
Hi Everyone,
My questions pertain to the attached figure.
-I have a sheetmetal part.
-I have a face that goes against another part, and so am using that plane as Datum A. This face constrains Translation in Z, and rotation about X and Y.
-I have six staggered dog-bone type feature (see detail view A for what I call the dog bone feature).
-Four of these constrain translation in Y and rotation about X. So The secondary datum needs to be based on these features.
-Two other staggered dog-bone like feature constrain the remaining degree of freedom , i.e translation in X. So the tertiary datum needs to be based on these two features.
My questions are
1. What is the best way to select the Datuming scheme? Presently I have A as the primary datum, B-C as the secondary datum, and C-D as tertiary. With B being defined by two points on the dog bone, and C two points on opposite . Is this correct? Do you have a better for selecting the secondary on tertiary datum? Is there a way of using Composite datum so that I can use all four dog-bone features for secondary datum, and two vertical dog-bones for tertiary datum?
2. How do I tolerance the slot width (Detail A) I wan that dimension to be 1.3+/- 0.08. But I recall that in ASME14.5, the opposite edges should have some overlap to be dimensioned with size control. So what are the alternatives to the wway I have dimensioned it, since the opposing edges on the slot are staggered and not overlapping?
Thank you everyone in advance for answering!
Siva
My questions are
Siva
