Hi guys:
I'm trying to find the correct tool to remove the crosspoint/philips-like covers on the radial pump shown in the attached picture.
It is powered by the engine of a rally car and used for operating the power steering and the hydraulic shifitng of the manual transmission. Size is about 3 inches diameter and about 10 inches long, mounted on the engine block with multi-v belt connection.
The pump was made by Toyota Team Europe in the mid/late 1990s and I'm trying to get it operating, but it now has no pistons (other internals/eccentrics/one-way valves are ok, I think).
Any idea as to the tool used to remove (unscrew) the caps/covers over each piston bore? Covers are about 3/4 inch dia, but probably metric sizing. The pump body was made in-house, but the caps appear to be commercial - die cast, etc.
Thanks for any help you can provide. Bruce
