ella0509
- May 19, 2004
- 66
Hello, I wonder if any of you guys can help point me in the right direction. I'm looking for a material with the following parameters:
> ~2" Diameter Tube
> Excellent Chemical Resistance
> Low density
> Electrical Insulator
> 200 Deg. C Service Temp for <15mins
> 1 Bar.G internal pressure
> 100mBar internal Vacuum
> Pressure & Vacuum will be cyclic in nature
> Can be machined (Sealing features etc)
> Possible need for Epoxy style bonding
I've been suggested PEEK as one option, but the cost is quite high. Are there any others that may well meet the required specification, but come in at a lower cost?
Also are there any good reference sites / documents out there that compare the parameters of advanced polymers but include cost guidance? is excellent, but I can't see any cost info.
Lee
> ~2" Diameter Tube
> Low density
Lee
