Heat treatment
zhlin
I have a question regarding heat treatment of steel casting.
Is it acceptable/ok if a 9 hrs heat treatment chart shows an interruption - lets say 10 minutes?
Thanks in advance.
Please comeback with more details.
What is the material?
What part of the heat treatment was interrupted?
Assume 9 hours to be soaking times. A 10 minute interruption,might cause a drop in temperature of few 10's of degrees. Practically should not be a major cause of concern.
Learn the rules,so you know how to break them properly.
Dalai Lama
_____________________________________
Sorry for not reponse quickly.
The material is ASTM A487 Gr 10 Cl B.
Thanks all.
zhin,
You should indicate your heat treatment temperature and the variations in your specific case...
zhlin,
I have the spec with me,which specifies the austenitizing temperature as 1550F(845C), liquid media quenched to below 500F(260C) and then tempered at 1100F(595C).
Why have you gone for such a long austenitizing cycle ( I am assuming,as you have not mentioned)?
Dalai Lama
Dalai,
The part is 8", which was the heat treat time came from, I think.
Yah, per the spec, it should be cooled at liquid and then have temper per the spec.
So I am going to dig up more information.
Thank you!
K
The applicable AMS specifications discuss cycle interrruptions. Usually the are allowed if they are minor and your Quality System has a procedure for handling them.
admin@heattreatforum.com
