sbozy25
- Jun 23, 2005
- 395
Ok, so I am having a monumental brain fart right now and it is really bothering me.
Here is the situation:
I have an axle with an upper and 2 lower torque rods that connect and all run longitudinally. The upper torque rod normally sits on the CL of the axle, but in this case, the customer wants to move it off center so they can use a common bracket. They are concerned that this offset will cause an issue with the end torque rods and their bushings.
I'm trying to find what the moment will be at each end as a result of this uneven load. To simplify this problem, I'm assuming this is an supported beam, with 3 loads. I pulled out my Shigly to make sure I did this right, but I'm getting some astronomical values of moments to the 8th and 9th power. That can't be right, can it??? What's frustrating about this, is that any college freshman could probably do this... If only I could remember back that far, but it has been quite a few years, and I only have to do calcs like this once every 5 to 10 years...
I've attached a picture with the loads and dimensions.
Looking at Shigly, I am using the formulas for fixed supports with an intermediate load.
Which would mean the moment to the left side would be [(Fab^2)(3a+b)]/l^2 and the moment on the right side would be [(Fba^2)]/l^2
Is that right, or am I missing something with the FL values?
Definition of irony: A Ford Focus driver with ADD...
