I think some of the responses are getting a bit off-topic. The original question was regarding how to dimension in Y14.5M, not whether the method used was legal or consistent with any other standard, whether or not such standard is referenced within Y14.5M.
I've posted a (hopefully) clean drawing for ant77's geometry on my site
download it and review it with the following text:
Where to begin ... with datums! The most fundamental benefit of GD&T by ASME Y14.5M-1994 or any other standard, is that you can repeat the inspection process because you have datums to establish the origin of measurements. Your likely Primary Datum (let's call it Datum-G) will be the back face of the U-channel. This is better than the two feet of the channel because it minimizes the effect of warpage in the center panel. Put a Datum-G symbol on the back face or on a leader from that face (see Y14.5M-1994-Fig. 4-2, Datum-D, -E, -F). Next, the symmetry is visually about the centerline, so that is the desired location of the Secondary Datum (let's say Datum-A). To do that, put a Datum-A symbol inline with the arrow of the dimension line (see Y14.5M-1994-Fig.4-19, Datum-A or Datum-B). This indicates that the mid-plane is the datum feature, and that is where the locations will be measured from, and hopefully where the features will also be dimensioned from. The Tertiary Datum should be the face from which the 10,20,30 dimensions originate; label it as you would for the Primary Datum, indicated above, but call it Datum-K.
As the symmetry is visibly about the centerline, you do not dimension both of the symmetrical holes, just the location of one of them, with the dimension starting at the centerline (per Y14.5M-1994, if features on a workpiece appear to be symmetrical, they are assumed to be symmetrical, and those features not complying with a symmetry would need to be individually dimensioned). You will also need a Positional Tolerance on the 6X Dia2.50 callout (drop "HOLE"). A diametral tolerance zone of whatever tolerance size would be applied wrt Datum Reference Frame [G|A|K].
Of course, overall dimensions are needed, and a general tolerance covers all features not otherwise directly toleranced. Note that the trailing zeros are omitted and the C/L symbol is also omitted. You need to indicate the dimensioning standard under which the drawing was created.
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
