Designing a swimming pool enclosure that has three-hinged glulam arches. In the parallel direction the arches handle the wind load. Since the roof structure will be purlins framing to the arches and not bearing on the perimeter wall I say there needs to be a wind girt at the top of the wall that will span between the arches, similar to pre-engrd mtl bldgs. A colleague has convinced the contractor that the walls's double top pl does the job and no wind girt is needed. What do you guys say?
