I'm currently reviewing a submittal that indicates residual-type ground fault detection to be provided for an existing ungrounded 12,470-volt system that currently has no ground fault indication. I'm rejecting this because I do not believe this can work.
My first preference would be detection of zero-sequence voltage. Unfortunately, it is probably not possible to install PT's anywhere on this system due to space restraints.
Therefore, I'm considering zero-sequence current detection. I'm still not convinced this will work, but have not been able to find any real documentation either way.
Any thoughts?
Any thoughts?
