fastline12
Aerospace
- Jan 27, 2011
- 306
We are an engineering firm but NOT a geothermal firm. We are wanting to install a geo heat pump system in a new shop space. I think the open loop water system has been nearly ruled out. Concerns of any water supply issues as well as the need for a water to water exchanger to run closed loop fluid to the HVAC unit. We do not want to chance running ground water directly through the unit and as well, if water became an issue, we would have no water as well as no HVAC.
This brings us to vertical or horizontal loops. Vertical seems to make more efficiency sense but would take many years to recover the drilling costs. a horizontal excavation would be free for us.
The closer we can stay to 55-60*F inlet temp, the more efficient our system will be year round. It seems the common practice is to use PE pipe but in looking at the thermal conductivity, the question was raised if we can get anywhere with metal piping? It would then make the most sense to be in a water saturated environment (vertical loop). In a horizontal loop, it looks like the earth conductivity would be the bottle neck thus requiring hundreds of feet of piping.
Does anyone have direct experience with geo systems in the midwest to know which has been working better in practice? The thought also came to mind to have a single well dug where we could install a custom metal heat exchanger but not knowing how the layers of rock and water would interact and perform, it would be a guess for us. Dipping loops of PE pipe in a water well just does not seem an efficient use of direct water exchange but maybe that is all the ground water will take.
Looking at the thermal conductivity properties of stainless and Al compared to PE sure makes one want to reach for metal but if the earth cannot utilize it, I guess there is no use.
Thoughts?
Thoughts?
