My Ruud forced air gas fired heater/central air unit fan motor seized after 4 years & 10 months. The motor is a GE 1/2 hp (4) speed motor model S018S with sealed bearings. I used to have a Lennox unit that run for 30 years. I run the fan continuous summer and winter. Suddenly it started screeching. At first I thought that the fan wheel was rubbing the scroll but it turned out it was the bearing seizing after it got hot. I bought a replacement from the Ruud dealer but the replacement is a Protech motor. I noticed that the GE motor did not have fan type blades on the rotor to cool the back bearing. The rotor at the front end had blades on the rotor but they did not look like good air movers. They were stuby and the sided taper down towards the end of the blades. The replacement Protech motor had efficient looking fan blades at each end. Without the fan to cool the GE motor, I imagine it building up heat first gradually until it dried up the lubricant in the sealed bearings (no evidence of lubricant leaks at each end but turning the rotor makes you feel the dry bearings). Then with bearings dried up, the build up of heat occur faster until the bearings seized. Don't you agree with me that this is a GE design defect? What is the maximum temperature that a sealed bearing can tolerate before the lubricant degrades?
