Defected 200kw Motor rotor
Emad Shaaban
LY
Is there any method to detect failure in the rotor of a 200 kW motor that produces a humming noise? In a previous experience, a similar motor exhibited a similar noise, and upon disassembly, we found that its rotor had elimination gaps.
I am wondering which technique could help determine whether the motor has the same issue without taking it to the workshop. Please note that the motor is controlled by a Sepam M20, and all bearing readings are sufficient.and what is the reasons behide this issue ?
please see Pictures
There is probably a problem with breaking some rod on the rotor. This can be detected reliably when motor is running under load using the Motor Current Signature Analysis method or vibrodiagnostics .
thank you Panter.
Is there any space to tell me more about these methods
You may try energizing one winding with DC and then turning the rotor.
You may be able to detect a cogging or a variation in the torque required to turn the rotor by hand.
And then, maybe not.
It depends.
It is a quick and easy test, but not always conclusive.
thank you Panter.
I used this technique 20 years ago with old SKF CMVA 60 instrument. Today there are many others that offer current analysis in one or all three phases of AC motor , so you have to do a little research. I am attaching a document of SKF on how it work and how vibration diagnostics can together provide signals and a reliable assessment that something is wrong with rotor cage.
